- 2076
- ek4 b16a sir
- p72
- intake whale penis, stock inj, stock cam, stock header
right now mostly hesitate problem when in gear 4 or 5 while driving in other gear seem unable to duplicate hesitate problem. I'm using Innovate LM2 wideband and observe during hesitate the afr lean till 19.3:1. Need some expert advice are this gear adjustment issue as i didn't dare to touch the setting. Right now gear 4 -29.7 and gear 5 -44.5 as base calibration. Thanks.
this issue came after changing new o2 sensor..
b16a hesitate part throttle.
excaliburcombo
excaliburcombo
Re: b16a hesitate part throttle.
i try swap fuel filter, spark plug, and last plug wire seem the hesitate became less...
Seems like a few people is having this same issue. I have the same problem and have been tuning my own car since 2004. This problem started for me last year. Hopefully you find the problem. My issue happens when the cooling fan turns on and off, but mostly when it turns off. The car would stumble and the ECU disconnects from laptop while datalogging. Leaving me to believe that the ECU is swiftly turning off then on when the cooling fan turns off.
excaliburcombo
i already found the problem. new o2 sensor having slow respond and make short term fuel trim cut max fuel. Swap with known good honda o2 sensor the hesitation/jerk go away. Thanks.
Great that u figured it out. Thanks for sharing.excaliburcombo wrote:i already found the problem. new o2 sensor having slow respond and make short term fuel trim cut max fuel. Swap with known good honda o2 sensor the hesitation/jerk go away. Thanks.
