FlashProManager V1.8.3 beta (Bluetooth)
FlashPro Manager software
VitViper
Re: FlashProManager V1.8.0 beta (Bluetooth)
Post by VitViper »
Hondata wrote:
VitViper wrote:Yes... I had one come into the shop last month, had a discussion with Doug about it... the ECU is "R9B-A03", which is listed as supported in the 1.6.3 update:
[ILX] Added support for the R9B-A03 ECU
However that's not the case -- FlashPro refuses to recognize the ecu and will not lock/flash the car. We were told this would get fixed in the "next beta". :/
We even had him send support info like 4 weeks ago, per Doug's request.
Yes, we added the binary R9B-A03 in 1.6.3 but the problem you had was related to the ECU part number. It should work now.
I suspect as much -- we'll try 1.8 on it and see how it goes.
Hondata wrote: So you want misfire disable on the 06 Civic? We'll add it in.
Absolutely, it's been a problem with the 06-11 Civic calibrations for months -- I cannot use any very large injector without triggering a million codes.
MJz
Post by MJz »
R-12914 wrote:
Spunkster wrote:what error are you getting?
If i try this:
1. Plug the FlashPro into the diagnostic connector and switch on the vehicle ignition.
· Primary calibration - press the Program button for at least one second.
· Secondary calibration - holding the Datalog button down, press the Program button for at least one second, releasing the Program button before the Datalog button."
Than the FlashPro does nothing!
I have also upload the Cals again from the Notebook to the Flashpro and than from the Flashpro to the ECU, but the same as before! :(
Yes!I also got this problem...
R-12914
Post by R-12914 »
MJz wrote: Yes!I also got this problem...
What car do you have?
@Hondata: When will the problem be fixed?
2008 Honda Civic TypeR FN2
Rotrex C30-94 supercharged with relocated IAT
Powered by ASNU 092/FP330E fuel pump & ASNU 090/750cc fuel injectors
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
I've narrowed it down. It only affects FlashPros without Bluetooth. It will be fixed and a release made in the next few hours.
Six_speed_demon
Post by Six_speed_demon »
Hondata wrote:V1.7.3 (2 Apr 2014)
  • FlashPro firmware updated to version 61
  • Bluetooth enabled
  • [07-08 TSX] Added ability to program AT ECU with MT program
  • [TL] Added ability to program AT ECU with MT program, only base model ECU (RDA-A85)
  • [2006 R18 MT Civic] Added support for the RNA-A150 calibration.
  • [CR-Z] Fixed misfire code disable.
V1.8.0 (3 Apr 2014)
  • FlashPro firmware updated to version 62
  • Fixed Bluetooth detection
Download here
just wonder if the link to 1.8.0 was removed? for some reason I get a error and it states "not found" also I have tried updating thru flashpro manager and It keeps stating programing is not a 32 bit program and closes down. just wondering if anyone else is having this issue?
It is because we are in the process of doing an update.
VitViper
Post by VitViper »
Shift + F1 once again is back to opening the help file instead of showing the normal fuel tables... ugh :(
MJz
^_^
Post by MJz »
My one is Civic ABA-FD2 Type R。
R-12914
Post by R-12914 »
Bug is fixed - THX! :)
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
VitViper
Post by VitViper »
Thank you for the Civic cal misfire detection toggle.
terenceng
Post by terenceng »
I read the flash pro help file.
V1.8.1 (4 Apr 2014)
• FlashPro firmware updated to version 63
• Bluetooth enabled
• [2012+ Civic] Added support for RX0-K020 through RX0-K060
• [CRZ-Z] Added support for RTW-H510 and RTW-U510
May I know does it mean FlashPro is now supported ECU part number RTW-U51? Any different between RTW-U510 and RTW-U51?
Thank you,
The 3 digit codes are part numbers (RTW-U51) and the 4 digit codes are calibration IDs (RTW-U510).
terenceng
Post by terenceng »
Hondata wrote:The 3 digit codes are part numbers (RTW-U51) and the 4 digit codes are calibration IDs (RTW-U510).
Does it mean version v1.8 is now supported ECU code RTW-U51? Asian First Generation CVT CRZ?
Thanks!
Terence
IcEMoCHa
Post by IcEMoCHa »
I'm having the non bluetooth version of the flashpro. The latest firmware seemed to have fixed the button issue.
But now the flashpro doesn't turn on/turn off itself (no lights) when there is no activity and cannot datalog/program.
I have to unplug the obd and replug it in before it works.
terenceng wrote:Does it mean version v1.8 is now supported ECU code RTW-U51? Asian First Generation CVT CRZ?
It should do. The problem is that we can't tell 100% what calibration is in each ECU from the part number.
