what do you mean by the first one i got? is it called the cold air? i can send that...but i got less knocks on the very torquey one than the cold air one just so you knowcurtusz wrote:yeah the first one you got there is the best so far ... if you want to send that kal ... I can retard ignition where u got knock
Password JDM Power Chamber Basemap??
Re: Password JDM Power Chamber Basemap??
2002 DSM ACURA RSX TYPE-S / K-PRO / PWJDM INTAKE / OBX V2 HEADER / HASPORT MOTOR MOUNTS / INGALLS ENGINE TORQUE DAMPER / K-TUNED BILLET SHIFTER / SCHROTH RACING HARNESS / ENERGY SUSPENSION
ok here is the kalcurtusz wrote:very torquey and favorite so far log.kdl ... that 1
hey man this was that crazy powerful kal if i remember correctlycurtusz wrote:hopfully last kal for this map
http://www.hondata.com/forum/download/file.php?id=6285
and here is the log for the one in the post above...lets try to get the most out of this oneprotoge91 wrote:heres the very dangerous torquey kal log the one with too much knock..however this was the most powerful
http://www.hondata.com/forum/download/file.php?id=6308
ok heres the kal that i want us to work on ill log on both of them tommoro
ok heres the log for the one above. it was taken day before yesterday...havent changed anything
http://www.hondata.com/forum/download/file.php?id=6307
ok heres the log for that map driver plus son 160lbs temperature 66 degrees farenheit
log
!!!!! we did it!! no knock!!!!
here it is. driver 140lbs temp 52 degrees farenheit
here we go driver 140 temp 52 degrees F
ok here it is
here it is
ok here we go a lil stronger did you alter vtec point? if so i think i can feel that
a couple of knocks on this one..felt even better tho
