Password JDM Power Chamber Basemap??
protoge91
Post by protoge91 »
KPRO (cold air intake, toda headers, cat back map)
2002 rsx type s
Comptech header
Stock exhaust
Cold air intake
Vtec set at 3500
Will be switching from cold air intake to password jdm this week. What will be my expected results
And Willi have to tweak this basemap or use another?
2002 DSM ACURA RSX TYPE-S / K-PRO / PWJDM INTAKE / OBX V2 HEADER / HASPORT MOTOR MOUNTS / INGALLS ENGINE TORQUE DAMPER / K-TUNED BILLET SHIFTER / SCHROTH RACING HARNESS / ENERGY SUSPENSION
protoge91
Re: Password JDM Power Chamber Basemap??
Post by protoge91 »
Someone has to know something
protoge91
Post by protoge91 »
curtusz wrote:I think you should only have to tweak the map your using
ok and how so? and where in the map? generally speaking of course
protoge91
Post by protoge91 »
TodaHeaderDatalog.kdl
well heres a datalog of my car running on the toda headers map can u tell me if everything is safe??
protoge91
Post by protoge91 »
curtusz wrote:you had 8 knocks all together ... and apparently your car hits 86mph at 8000 rpm .. do you have a different final drive in there ? (assuming its the same 6speed manual as euro r we have here ) I wouldn't use that map for now .... you need to log your fueling its a deadline on the data log. once you got that I could adjust your map for you ... keep you pedal 100% down use a safer map till you can get some numbers in your fueling
so 8 knocks is good or bad?? and what do you mean that fueling is a deadline??
protoge91
Post by protoge91 »
as far as setup i am running a lightweight 10lb flywheel and 88a super stiff hasport motor mounts
protoge91
Post by protoge91 »
curtusz wrote:My ep3 type r limits out at 8600 at 84mph just found it weird though rsx had same gearbox yeah I have mounts pretty sure our factory flywheels are 10lbs did u manage to get your air to fuel to log ?
yes tranny is identical as far as i know and no you have stock 10lb flywheel i upgraded to one...and i thought i did but i guess not im new to kpro man so idk
protoge91
Post by protoge91 »
curtusz wrote:We all got learn somewhere you will pick it up fast as you get on... Here we have to use wideband controller to log our a/f. But I'm sure that I read yours are wideband anyway have a play with settings
yes according to my mechanic our are wideband as well
protoge91
Post by protoge91 »
is 8 knocks during a 3rd gear WOT pull bad? or acceptable? ive heard average is 7-10 but im not sure. i decided im not gonna rag on her too much until im tuned and running safely...not worth the risk
protoge91
Post by protoge91 »
curtusz wrote:No I get 0 knock on a 3rd pull, once you can start logging a/f I can get you tuned enough to rag her to bits, I'd use the cold air kal it's the safest map for your for now when u start logging a/f we can build u a map or tune on a existing basemap
ok cool man thank you i appreciate the help how much do you charge for your services??
protoge91
Post by protoge91 »
curtusz wrote:And u got 1 knock during your 3gear pull.... You had 7before you started recording
ok so why so many when i was just driving normal? and is 1 bad?
also if i go back to the col air kal can i still lower vtec to 3500rpm??
protoge91
Post by protoge91 »
curtusz wrote:I used to get knock bad on somebody's map I tryed... You can try lower vtec and log for knocks and enable flash mil knock detection on kmanager so your engine light flashes when you get knock aswell... But as soon as u get your a/f you can play with vtec safer
yes i have that feature setup to flash when i have knock...its useful. so what do you need me to do send you another data log?? i like the toda headers map alot since i have headers and an intake im just missing an exhaust
protoge91
Post by protoge91 »
curtusz wrote:On display tab you should have something that represents a/f thou you may have to set something up to make it read on the kpro in (I'm guessing in settings or parameters ) once you get the kpro to read it you can 3gear pull from 2000 to redline then I can adjust fuel and get it running consistent and safe
ok cool man ill do that i a couple hours when i get off work and PM it to you or put it here on this thread. thanks again man!
protoge91
Post by protoge91 »
hey man sorry been busy im gonna upload a datalog today. is that cool? if you dont mind taking a look at it for me. thanks
protoge91
Post by protoge91 »
curtusz wrote:Sure I finish work in a hour and half so il get straight on it
o cool wont have the datalog ready till maybe 8pm standard eastern time over here on the east coast of the US. but when i do ill upload it to you and tell me what ya think. once again i appreciate all the help!
btw i have my password jdm powerchamber on there no so no moe cai. its just the powerchamber&my obx/comptech headers&stock exhaust
