high and low boost question
nitefr3ak
Post by nitefr3ak »
i am using my s300 but i want to utilize it even more ....
i need some help i dont know what i need to do so i can use the option for high and low boost
like i know b5 is the wire that the ecm uses for the input but what do i have to do physically the vehicle is eg1 honda delsol si
now the switch lights up and all but what do i need to do to the switch to have the ecm recognize the ac switch other then select it in the drop down ....... i know this is a lot to ask but is it possible for some one to do a write up on it like what needs to be removed added and rewired and how to ...... there is no ac system in the but it did have one installed at one point any help is appreciated thanks
skullbasher
Re: high and low boost question
Post by skullbasher »
really easy man. just choose a pin from the dropdown menu under boost low/highboost switch and find that pin that goes to you ecu and your going to have to cut that wire and fuse a new wire to a switch which grounds. you can find the pins on google images or something
nitefr3ak
Post by nitefr3ak »
hey skull i havent been able to play with it but i want to use the ac control switch ... so your saying that i have to cut the wire at the ecm b5 and switch the power on the switch and ground that then take the other wire and run that to b5???
sorry if im asking dumb questions i tend to make things that are simple and turn them into something worse then what they are
nitefr3ak
Post by nitefr3ak »
hey skull basher i figured it out thanks to you and spunkster i just need to set it up for the current boost level i am running now for high .... i ran a non-momentary push button for the hugh boost setting to a button on the steering wheel and im using a twist lock connector for the wire for the button but i do notice in the s manager that if i ground the wire to the column it goes from off to on so that part is good im just starting to play around with it but this damn snow wont let me get it in sort of speaking lol but thanks any way ..... you where very correct shits mad eazy
again thanks
