can somebody take a look at my h22 base map???
hi i have a h22 (mostly stock only a milled head and type s cams, no iab, 450cc dsm injectors type s single crank pulley, m2b4 lsd trans, kidd racing header)in my crx and it keeps bogging on me in wot. Can anybody take a look at my datalog and lemme know....plz and thanks
Monnoracing
Re: can somebody take a look at my h22 base map???
Give this a try if you have any problems with WOT cutting out you have a mechanical issue. Fix all CEL codes.
Thanks and will do.Monnoracing wrote:Give this a try if you have any problems with WOT cutting out you have a mechanical issue. Fix all CEL codes.
this is the datalog. I calibrated the tps and moved vtec down. also had a cel for injector error and BARO sensorMonnoracing wrote:Give this a try if you have any problems with WOT cutting out you have a mechanical issue. Fix all CEL codes.
