Base map for f22b1 sohc vtec????
jordanelo
Post by jordanelo »
Is there anyone that has the base map for a stock f22b1?? I've searched the vault and couldn't find any. I know someone has got to have one. Or does anyone know if the stock h22a map can be used with slight changes in fuel/ignition?? It's a 94 accord ex vtec. It is obd1. I find it strange this map isn't included with smanager. I could use a basemap until I swap in my h22. Current ecu isn't working due to fuel pump relay gremlin issue traced it back to ecu. I have hondata so I figured i'd try to use it rather than buy something else.
Osei
jordanelo
Re: Base map for f22b1 sohc vtec????
Post by jordanelo »
Anyone???
