parameters>tps>tip-in fuel
Johnny_9
Post by Johnny_9 »
please provide details and explanation on this new function. doesn't seem to be in the help file. does the rate increase or decrease the sensitivity of tps changes before tip-in fuel is triggerred?
skullbasher
Re: parameters>tps>tip-in fuel
Post by skullbasher »
HONDAT PLEASE CHIME IN
Changing the rate will change the shape of the curve you get when tipping in.
Johnny_9
Post by Johnny_9 »
Can we clarify on how this [tps>tip-in fuel] differs with the tip-in under [fuel trim] ?
Johnny_9
Post by Johnny_9 »
In the help file (and calibration) we have
Tip-in Fuel Normal
At 31F ECT: "Rate" is 77
At 145F ECT: "Rate" is 128
1) What does the lower number (77) represent vis-a-vis the higher number (128)
I would have thought a bigger enrichment (i.e. larger "rate" number) is required at colder temperatures - please clarify as it is counter-intuitive.
2) What does increasing the number "rate" do?
3) Under Tab "Fuel Trim" there also is a "throttle tip in trim" - how does this differ with and/or interact with the above.
Johnny_9
Post by Johnny_9 »
Spunkster, appreciate if you check this with Hondata and revert. Thanks.
The numbers are parameters to a complex function which determines how much tip in fuel to use. They don't have specific units. If you get too much tip in fuel, then decrease the rate, and vice versa.
