Hi everybody,
Could someone help me with my map?
B16a2
- AEM CAI
- NIPPON 81.5 TYPE R pistons
- MSD KIT
- WALBRO FUEL PUMP
- AEM WIDE BAND
- IRIDIUM SPARKS
I also have, s2 pro2 cams, s2 valve springs, supertech titanium valve retainers, buddy club high compression head gasket, AEM fuel rail and pressure regulator, 500CC fuel injectors... but I didn't put all of these yet. Actually I'm little afraid with this cams.
Currently I'm using gas but I can use Ethanol as well.
What do you guys suggest me?
Tks in advance
B16A2 with 81.5 type R pistons - MAP HELP
R G Marendaz
Re: B16A2 with 81.5 type R pistons
B16 crank and b16 rods with type r 11.1:1 pistons right. Whats the gasket thikness
tuning upon request
347-989-5028
9.23@167 B18C street/track tuned
HP unknown
347-989-5028
HP unknown
R G Marendaz
I think is the same like the original.
Re: B16A2 with 81.5 type R pistons - MAP HELP
You should be around 10.6:1 with this setup. Use a jdm B16 base map. 50 psi of fuel pressure with factory injectors. It should run and get it to a tuner. then swap the injectors and tune it.
tuning upon request
347-989-5028
HP unknown
347-989-5028
HP unknown
R G Marendaz
I recorded the datalog with stock injectors. Find enclosed, watch and than let me know what you think about it.
Tks
Tks
you need to fix your speed sensor. and you running lean at wot. part throttle looks ok.
tuning upon request
347-989-5028
HP unknown
347-989-5028
HP unknown
