B16A2 with 81.5 type R pistons - MAP HELP
R G Marendaz
Post by R G Marendaz »
Hi everybody,
Could someone help me with my map?
B16a2
- AEM CAI
- NIPPON 81.5 TYPE R pistons
- MSD KIT
- WALBRO FUEL PUMP
- AEM WIDE BAND
- IRIDIUM SPARKS
I also have, s2 pro2 cams, s2 valve springs, supertech titanium valve retainers, buddy club high compression head gasket, AEM fuel rail and pressure regulator, 500CC fuel injectors... but I didn't put all of these yet. Actually I'm little afraid with this cams.
Currently I'm using gas but I can use Ethanol as well.
What do you guys suggest me?
Tks in advance
Progress
Re: B16A2 with 81.5 type R pistons
Post by Progress »
B16 crank and b16 rods with type r 11.1:1 pistons right. Whats the gasket thikness
tuning upon request
347-989-5028
9.23@167 B18C street/track tuned
HP unknown
R G Marendaz
I think is the same like the original.
Progress
Re: B16A2 with 81.5 type R pistons - MAP HELP
Post by Progress »
You should be around 10.6:1 with this setup. Use a jdm B16 base map. 50 psi of fuel pressure with factory injectors. It should run and get it to a tuner. then swap the injectors and tune it.
tuning upon request
347-989-5028
HP unknown
R G Marendaz
I recorded the datalog with stock injectors. Find enclosed, watch and than let me know what you think about it.
Tks
Progress
Post by Progress »
you need to fix your speed sensor. and you running lean at wot. part throttle looks ok.
tuning upon request
347-989-5028
HP unknown
