Need Map for h22a4 boosted UPdate 5/27
sIx
Post by sIx »
Just gt this car last week, its running super rich, and throttle response is horrible, if I give it more then 50% throttle it hesitates untill it hits 4k rpm then it goes, ive yet to go over 5k rmps and rarely even hit boost. Im new to this but know a little, but need some help, been reading up on the s300 and figured I can just change the map and it should run alot better, untill I can save money to take it to get it dyno tuned......Not trying to get more power, just want it to run normal and more efficiant
Listed below are the parts I have on the car....
h22a4 5spd LSD tranny - stock internals
td04 t3/t4 turbo .50 trim
Greddy bov
tial Wastegate= 7-8lbs boost
!!!!!!!!!! " 440CC Delphi 42lb (01D030B) injectors!!!!!!!!!!!!
skunk2 pro mani
!!!!!BBK Power Plus 70mm Throttle Body
3inch exhaust OBX R
Godspeed Intercooler
Msd Ignition
Apexi Postive Management system
AEM fuel rail
Hondata s300
Still has AC " works" and power steering :)
Thats about it Hope that helps yall help me !! Thanks in advance.....
ps....just got the software on my laptop, and cable ran from ECU, just havent hooked it up yet, but will when I get off work today and test it out.....Hope someone can help me out !
sIx
Re: Need Map for h22a4 boosted
Post by sIx »
Can someone please look at my attachment, please explain to me what the heck it all means......advise would be greatly appreciated.
Progress
Post by Progress »
If you dont know anything about how and what. You should get your car tuned.
tuning upon request
347-989-5028
9.23@167 B18C street/track tuned
HP unknown
sIx
Post by sIx »
yea.....ok.
im learning dude....but thanks for pointing that out, im sure you feel better about urself now.
sIx
Post by sIx »
ps....not tryin to be an ass, just took ur comment a little personal, looking for advise, im eager to learn, which I am, been reading up ALOT on this and I am learning.....slowly but surely, and as for the tune, I dont have the money to get it tuned right now,,.,.,.thats why im looking for a decent map to help the car run better and more efficiant till then. Hope u understand, and are willing to help.
Progress
Post by Progress »
The only way u gonna learn is by tuning it. Some people learn by blowing 10 motors some 2. You looking for a base map that might start your car and able to drive, but somewhere in the map your motor might react differently and can cause damage. U wanna learn. Get a b18a 750cc and start tuning, thats how u learn. i've been there, i got a 10 sec daily and 9 sec track trying to get it into 8's hopefuly if hondata lets me all street tuned never seen a dyno tuned by me.
tuning upon request
347-989-5028
HP unknown
sIx
Post by sIx »
^^ I couldnt agree more. Thats exactly what im doing is Learning. My car starts up fine, and drives good as long as I shift around 2500 to 3500 rpms it runs like a champ. If I give it half throttle though, at first it hesitates, like something is holding it back, then around 3500 to 4k takes off like a bad out of hell....I know it needs a tune.... as of now, Im using smanager software on my laptop, connecting to the ecu, and going from there. Im going thru the tabs of info and seein what each one is and does. It will take a little time since theres so much stuff on the program..... but I dont know just yet, whats good, whats bad, and how to change it..... im NOT gonna start changing stuff and not know what im changing for that exact reason you stated " blowing up motors " I have a good amount of common sense....besides, I have blwon up motors before. had a 4dr eg civic jdm d15b greddy 15g kit around 180Hp and blew a rod, due to oil failure, and yes, it was all preventable, if I only replaced the oil return line like i was suppose to. So not going that route this time....its not a daily, my wife bought it for me as a gift last week, to give me a hobby , so its just sitting in the garage.....I think i did it right, but maybe not....I did the datalog thing, not driving it....just at idle and me reving it up a bit........attached it this post...if you or anyone has a few mins....take a look at it, and tell me what you think. If anything looks out of the norm or bad. Also....it gave me two error codes... 9 and 10 one being cylinder sensor, and other was IAT or intake air temp sensor.....looking those up to see whats up.
sIx
Post by sIx »
OHHH and congrats on hitting the 9's man....hope the 8's ur seeking come up soon. More info bout the cars if ya dont mind.
Progress
Post by Progress »
You have a crank position sensor. And also do a datalog while you drive. Go through gears and rpm where it hesitates. You can contact me if you want.347-989-5028
tuning upon request
347-989-5028
HP unknown
sIx
Post by sIx »
Thank you kind sir.... Just got home a bit ago from work, and about to eat and then go take the lude out for a few and do that datalog.... Ill text you in a while. Thanks again
sIx
Post by sIx »
6 mins of me driving
Progress
Post by Progress »
Can u send the calibration and do u have a wideband. Did you check if you have a crank sensor
tuning upon request
347-989-5028
HP unknown
sIx
Post by sIx »
No wideband.... tried contacting the guy I bought the car from to confirm but he yet to reply. gimmie an email to send the calibtation too
Progress
Post by Progress »
U can post the calibration on here
tuning upon request
347-989-5028
HP unknown
sIx
Post by sIx »
Hope this is what ur needing.
Its saying the file is Not downloadable yet, is it something im doing wrong?? of one of those things that I have to post so many post in order to have access to add files to the posts??
