k20a2 still knocks
fugazzyek
k20a2 still knocks
Post by fugazzyek »
hi guys im new on that but knows the basic corrections but still cant correct or modified the map for no more knocks,,,,
btw i add 10% all fuel tables and retard 1 degree all ign tables
i made this datalog on 3rd gear yesterday
my mods are k20a2 2004
edge 4-2-1 headers
injen sri
pr2 img
pr2 tb gaskets
thanks for your comments and help
im looking for the tips to make my car runs better
mdelrio1991
Re: k20a2 still knocks
Post by mdelrio1991 »
fugazzyek wrote:hi guys im new on that but knows the basic corrections but still cant correct or modified the map for no more knocks,,,,
edge 4-2-1 headers
injen sri
pr2 img
pr2 tb gaskets
your car is running way too rich throughout the whole data log. id suggest removing 5% fuel at all rpms columns 8-10 then data log and repost. fine tune your a/f before you start messing with ignition.
also post the kal your using.
keto06
Post by keto06 »
this log is terrible
07 Civic Si Sedan (sold)
17 Civic Si Sedan (daily)
02 RSX Type S (project)
Hit me up for free Hondata Help!
fugazzyek
Post by fugazzyek »
edge 4-2-1 headers
injen sri
pr2 img
pr2 tb gaskets
Ok im gonna do it and then let you knows
fugazzyek
Post by fugazzyek »
keto06 wrote:this log is terrible
really :(... im new on this
keto06
Post by keto06 »
i havent used this map in forever, but give it a try.
log a WOT Pull just like you did before. Let me see how it turns out.
Also, you said 4-2-1 header. Is it ... or catted?
fugazzyek
Post by fugazzyek »
keto06 wrote:i havent used this map in forever, but give it a try.
Hi, is ... btw
fugazzyek
Post by fugazzyek »
throw me the primary O2 sensor error,,,
keto06
Post by keto06 »
fix it then. I can't tune it without it working.
fugazzyek
Post by fugazzyek »
keto06 wrote:fix it then. I can't tune it without it working.
but if i use the stock Kal again, doesnt show me the O2 sensor, what would be??
thank you
keto06
Post by keto06 »
weird. If nothing else, copy all the tables over and make sure all the paramaters and RPM indexes all match and post another log.
fugazzyek
Post by fugazzyek »
keto06 wrote:weird. If nothing else, copy all the tables over and make sure all the paramaters and RPM indexes all match and post another log.
Ok ill do it and then i let you know!
fugazzyek
Post by fugazzyek »
ok those i make today at afternoon while was working, i gonna send you more after,
btw i found that the upper radiator hose hit the SRi rubber elbow so this pass the heat to the intake manifold,,,that would be one of the knocking facts right??? Iat high temperature..
thank you for the help
keto06
Post by keto06 »
Need a MUCH bigger file for cruise tuning. Almost useless. That 6th log wasnt useless, but I didnt get a ton off of it.
Also I couldnt help with the knocks because none of the logs had any. RECORD THOSE KNOCKS! :P IATs were 90-100 degrees. Not great but could be MUCH worse. I live in Texas :/
Oh and TURN OFF CLOSED LOOP FOR LOGS!
That being said, this one should be a bit better. Though Im concerned with how low your map number is. Where are you located?
fugazzyek
Post by fugazzyek »
keto06 wrote:Need a MUCH bigger file for cruise tuning. Almost useless. That 6th log wasnt useless, but I didnt get a ton off of it.
ok i gonna make the logs with this kal and also with close loop off to see the knocks and then i post them
thank you for your help i noted that the ign was more stable!!
