does anyone by chance have a starting tune for a k20/24 engine full spec below.
fd2 oil pump
acl bearings
k24 crank
s2 rods
arp rod bolts
wiseco 12.5:1 pistons
s2 hi comp valves
s2 springs
s2 ti retainers
s2 intake manifold
s2 cai
s2 megapower headder
s2 stage 2 cams
s2 74mm throttlebody
74mm hks exhaust system.
no afm as fd2.
many thanks.
tony
k24/20 built motor runing in cal.
stevegarage
Re: k24/20 built motor runing in cal.
i think you can use the reflash cal for running in the engine. as it goes to dyno adjust the timing first. i just done k24/20 without any issue. enjoy tuning:)
