What's the error code "ignition input signal" (error code 15
BoostedLS98
Ok so I was at the track tonight. Launched at the line in first ad then came 2nd and then the car died. I opened up my laptop and checked for codes on my s300 and it came up with error code 15 ignition input signal. Please help!! Car won't start now and I'm getting mixed opinions.
V-Spec race development
Re: What's the error code "ignition input signal" (error cod
Most likely your igniter went bad. Change that out and it should start right up, hope that helps you.
Last edited by V-Spec race development on Sun Mar 24, 2013 11:44 pm, edited 1 time in total.
BoostedLS98
it was that along with the fuse for ign coil and also the black/yel wire had a short at the fuse box. wasnt fun but got it fixed! thanks
