flashpro problems
flashpro problems
I'm having a problem with it iv installed it and when I go to check for updates an error message comes up at the bottom right of the screen. It does it then I try to do anything install drivers ect.
Re: flashpro problems
This error is not from our software, it is from your operating system or antivirus software. Try uninstalling any antivirus software and see if that resolves the issue.
The IP address 173.247.249.142 is from our website. It is because FlashPro is contacting our website to check for updates. Your firewall is blocking this. If you allow the activity then it should work for you.
