I need a tuned map for a stock Euro EP3 K20A2. Help please
zeroprobe
Post by zeroprobe »
Hi,
I've just bought a KPRO and I don't think it comes with a tuned map for a stock Euro EP3 K20A2.
I've searched on here and only see KAL files for EP3's with additional mods.
Would the base calibration ( k20a2-civictyper-tuned.kal ) suit my set up? I notice the VTEC is lowered but the rev limiter is still at 8100.
Can anyone help?
Thanks.
seanyreeves
Re: I need a tuned map for a stock Euro EP3 K20A2. Help plea
Post by seanyreeves »
my tuned k20 makes 215whp on the hub dyno, only a header and induction kit. can upload the kal for that if you would like
zeroprobe
Post by zeroprobe »
Hi,
Sure that be good thanks. Whats the VTEC kick in at?
seanyreeves
lower boundary is 4600 and upper is 6500, it has been tuned by romain levesque at eurospec2000. very reputable tuner.
seanyreeves
see attachement, running open loop as my o2 sensors arent wired in,
zeroprobe
Post by zeroprobe »
Thanks,
One quick question, obviously not going to be 100% but would a race header and intake make this map completely unsuitable for a standard EP3?
windspot
Post by windspot »
seanyreeves wrote:see attachement, running open loop as my o2 sensors arent wired in,
my car is wired there, i have to make it closed loop?
Nazul
Post by Nazul »
seanyreeves wrote:my tuned k20 makes 215whp on the hub dyno, only a header and induction kit. can upload the kal for that if you would like
215 whp, i think u mean bhp, not even a s2000 makes 215 whp
Nazul
Post by Nazul »
Why is immobilizer disabled, purge system disabled and ELD disabled?
Did u do a swap?
Then this map is not suitable for other users.
Nazul
Post by Nazul »
Since there is an overal fuel trim of 20%, running this map on a normal setup without header, will result in too rich mixture, fucking your engine on long term, so adapt this to 0.
windspot
Post by windspot »
Nazul wrote:Since there is an overal fuel trim of 20%, running this map on a normal setup without header, will result in too rich mixture, fucking your engine on long term, so adapt this to 0.
can you modify this calibration and upload it so i can load it to the ecu?
im not an expert in this, thats why im asking and i want to thank you for your time and help
Nazul
Post by Nazul »
Yes i can do this tomorrow sorry no k manager installed on windows 8 here at home only at work.
Nazul
Post by Nazul »
Here u go this calibration is adapted for closed loop all sensors on and no fuel trim
windspot
Post by windspot »
thank you very much!!!
where are you from?
if you come to greece i owe you a drink
Nazul
Post by Nazul »
Belgium, a little bit too far to just come over ;-)
