Wideband o2 for closed loop??
pingpong
Post by pingpong »
i was wondering if hondata is planing to make it possible to run aftermarket wideband o2 for closed loop operation in the near future?
most of the time when people do a "k swap" the oem wideband doesn't seem to work properly, hence people purchase aftermarket WBo2 like aem uego and innovate mtx-l .
also if there is a proper way to wire up the oem WBo2 could someone post a detail link of all parameters and wire up thanks
monchiy2k
Re: Wideband o2 for closed loop??
Post by monchiy2k »
Im looking for the same info, i have a AEM UEGO 30-4100, i want to configure as the primary o2....
dustyboner
Post by dustyboner »
If your having problems with the OEM sensor working on your swap, check out these 2 links:
Primary 02 Sensor Wiring - Check your wiring right here...
Wiring for bosch 13680 (02-04 type-s) primary oxygen sensor
monchiy2k
Post by monchiy2k »
I dont have any problem using the stock primary o2, just my race car have the aem uego wideband, so if i can configure to work as the primary o2, and display the info in the gauge too, is better than the stock and you have only 1 sensor, that sound great for me :)
