hi guys :)
im trying to connect my hondata to my laptop using latest ver of KManager but its seems the calibration on the ECU by ver 1.3.9
so im able to read the sonsors only but icant download the current map in ECU to my laptop becouse of this error
error msg " the calibration in the ECU (1.3.9.0 ) is from an older verion of KManger . please upgrade the ECU calibration before datalogginig from this ECU "
so i think i need need K-Pro Kmanger ver 1.3.9 to able to download my map first
then to load it again for update
Note : i dont have .kal file saved in my laptop becouse if i have it i can solve this issue
so from where i can download this ver 1.3.9 :(
and sorry for my bad english :)
Re: need K-Pro Kmanger ver 1.3.9
You should not backdate the software.
What happens when you download the calibration with 3.2.0?
as you see the pic
and after that im not able to download or save my map :(
and i dont have a map copy saved on my desktop :( becouse my car was belong other persone and icnt reach him to get the file
i think if you use any V under 1.3.9.0 or up V like 3.2
you can not save your calibration from ECU you must use 1.3.9.0
just i select "online"--> tools --> download
first i got error msg " the calibration in the ECU (1.3.9.0 ) is from an older verion of KManger . please upgrade the ECU calibration before datalogginig from this ECU "
and then tryng to read ECU and after that hange the software and close ,,and i try this also with another laptop
so plz from where i get ver .1.3.9 i need it badly to save my map only and after that i will upgrade it
email: anwar505@hotmail.com
emails:anwar.aldahmasi@gmail.com
Make sure you are not datalogging when you try to download and it should work without any problems.
thanx man , you are right
problem solved
problem solved
