on launch limiter no timing retard
maxwellsohc
Post by maxwellsohc »
while on launch limiter the timing won't retard.
any ideas
surfingsk8r
Re: on launch limiter no timing retard
Post by surfingsk8r »
Might help if you posted your settings or a copy of you calibration and datalog of the issue. Otherwise you going to get this answer...
Your doing it wrong, so many people complain about Hondata's anti lag, but those people are wrong. I can build whatever boost I want to with it. Id like to see someone setup the launch limiters on AEM or Motec or Haltech and get them to work if they cant get Hondata's system to work. That would be quite comical as those systems require a full understanding of the system and software to get them to actually work at all but again once you get it you get it and it works great. Hondata is the same way, you have to get it to get it to work.
If need be post your settings and Ill explain what each does for you and try and get you in the right direction Im at work so I cant look at your calibration on my work computer so that wont help me but your settings and some information should get me going.
