Gday.
Just wanted to know. Can I use one single input to trigger two different functions at the same time ? Eg - use d2 to trigger my high boost as well as a secondary fuel//ignition table ?
One input 2 functions ?
Re: One input 2 functions ?
As long as you have them set the same yes.
Lyle_57IAL
What do you mean set the same ? The example I gave in the first post
Will this be fine ?
Will this be fine ?
As long as the same input setting is used.
Lyle_57IAL
as in, they are both set to invert or normal?. Not either or
No, as long as they are both set to use the same input.
