Weird Wideband closeloop issue
Piv
Post by Piv »
Hello, I tuned an Honda Accord type R a while back and a weird problem appears now
The closeloop works when he wants, and sometimes when it doesnt work it throwing a Error code 1 Oxygen sensor 1 !
Here the .cal
And few logs
Any ideas ?
Never had that problem before and the voltage is always there, no problem with the O2 sensor :(
Thank you
Romain/Piv
Re: Weird Wideband closeloop issue
What sensor are you using to run closed loop from?
Piv
Post by Piv »
PLX :)
Do not use D14 as teh input for a wideband signal as it cannot read the full range of voltage. Use D10 , D12 or B6. That may resolve the problem.
VitViper
Post by VitViper »
For what it's worth, I'm using D14 on my car with an AEM sensor without issues. Same was done by the guy I got my S300 from.
Piv
Post by Piv »
Oh ok, I never had that problem before, may give it a try and see if it works ;)
Cheers,
Rom
