Tuning with E85 on s300
Engine:
Head:
H22a4
stock cams
port polished head
3 angle valve job
Crower titanium valves
crower dual valve springs and retainers
Cometic .030 headgasket
hondata heatsheild gasket
Block:
H22a4 w/golden eagle sleeves
polished crank
eagle rods
JE 11.5:1 pistons
high volume oil pump
Ks oil pan and pickup
Greddy timing belt
balance shaft delete
Euro r crank pulley
Add ons:
Hondata Cop
Golden eagle fuel rail
ID 1000's
walboro 255 fuel pump
aem fpr
Skunk2 68mm throttle body
p2r gasket
hondata 4 bar map sensor
Jrsc:
9lbs
ported charger w/ silencer ports welded shut
rebuild all of charger
Ported intake manifold/ port matched to head
Ported s pipe and matched to throttle body
Misc:
No o2 sensors
Will have 120 shot zex nitrous(dont need it done on basemap)
Also have the evolution h2b kit, ITR Lsd trans
Bisi header 2.75" collector
3" exhaust
If anyone can get me a solid basemap that would be great
