Cruise Control 6th Gear
eldelcivic
Post by eldelcivic »
Hello everyone.
First I want to apologize for my English as it is not just speak it and I used a translator.
I recently changed some things in the gearbox of my Honda Civic Type R Fn2 2007 and I have a short group (final drive) with a 5.46 6th longest (0.659) of an Accord with K24 engine.
The problem is that the Cruise Control works in all gears least in sixth gear!
You can solve this problem using FLASHPRO?
If so, you can help me contact all dealers of Spain except for KD PERFORMANCE.
Another problem I've found to change the FINAL DRIVE is now the speedometer lies more than usual. Currently with the changes and the size of my tires in 6th at 3000 rpms indicated 110km / h but it is actually 98km / h ... but I have seen that there is a section where these differences by percentage.
What is the difference between correcting the ECU and the DASH?
Can you explain this?
You can buy directly FLASHPRO Hondata or some European dealer?
Thanks for the info and I greatly appreciate the time you devote to clarify my doubts and questions!
Re: Cruise Control 6th Gear
The FlashPro should fix the cruise control, and in the next release should cope with the ECU gear detection too.
ECU speed adjustment changes the speed as reported by the ECU.
Dash speed adjustment changes the speed sent to the dash / gauges.
eldelcivic
Thank you very much ...
I understand that in future all such parameters may be adjusted and calibrated by Flashpro.
Could you advise a serious and responsible dealer in Spain?
Thanks again for your help!
Jochen1611
Post by Jochen1611 »
We have a problem with the 6th gear too.
We have done a map calibration by a supercharged fn2. Now the cruise control doesnt work at the 6th gear.
Why? I know my english is very bad, sorry.
Do not use the Race calibration.
