hey help speedometer dosent work
rsxtypes209
Post by rsxtypes209 »
hey i have 2006 rsx-s and i installed k-pro and speedometer does not work?!? also i check to see the Countershaft Driven Speed Sensor option and it is checked. why isint my speedometer working??
rsxtypes209
Re: hey help speedometer dosent work
i think its the vss becuz i use the self diagnostic and it works. can i drive my car like this??
rsxtypes209
okay i dont get why my vss is not working with k-pro and my speedometer dosent work?!? i put back in the stock ecu and still my speedometer dosent work. k-pro is not sensing vss also and i have no cel
What is the serial number of the K-Pro board inside the ECU and what is the serial number on the outside of the ECU case?
rsxtypes209
okay my vss is working on k-pro but speedometer does not work??
rsxtypes209
05001083 37820-prb-305-2054-100043 37820-prb-305-2054-100043 0J06
That is the correct ECU for an 05-06 RSX. If the gauge cluster does not work with teh stock ecu then there is either a blown fuse, damaged wiring, or the gauge cluster is faulty.
rsxtypes209
okay i tried the k-pro on another car and the speedometer does not work also i did the self diagnostic on cluster and all the guages work
What vehicle did you try the ECU on?
Why does the Gauge not work even with the stock ECU?
rsxtypes209
i both tried the k-pro on a 2005-2006 rsx-s and will check if the the speedometer works with the stock ecu tonight
rsxtypes209
okay speedometer works with stock ecu but not the k-pro?!? i tried beta version and the newest version also checked couter shaft 2005 rsx speed. whats going on?? also mileage is not working and gas is okay
Post a high quality picture of the inside of the ECU. This must be in focus.
