KPRO V3 analog input WB on PRA ECU
LK7R
Post by LK7R »
Good day Hondata. I have another KPRO v3 / KManager v3.0.3 question.
We have hooked up our Innovate motorsports LC-1 WB analog output to Analog0 input on Kpro v3. What we can not figure out is if there is any way to use Analog0 input for "Display fuel adjustment values SHIFT+F5" in order to easily correct A/F on fuel maps?
If we set Analog0 input in Parameters to Wideband - Innovate LC-1 to have those voltage values dataloged.
Then we set in Settings > Sensor Overlay to AN0.
Once we do some dataloging and try to do "Sensor Overlay SHIFT+F7" we get just voltage values from AN0 which is not very useable for A/F tuning purposes.
(note: no actual voltage values shown in picture as i do not have .kdl showing it on this PC)
Is there way how to set KManager to show "Display fuel adjustment values SHIFT+F5" for "Sensor Overlay SHIFT+F7"?
If not, could you please consider to add extra feature/option in Settings Wideband Input where user could be able to select which datalog Input use for Wideband Input Overlay operations.
Theese new analog an digital inputs are great addition to KPRO. They do help with those "#(@*&$@#" voltage offset problems. But on PRA ECU is badly needed to have posibility to do lambda overlay wiht data from those inputs.
Also on PRB/PRD ECU if someone for some unknown reason wants to use external WB then he would benefit from this feature too.
Cheers
Dan
Re: KPRO V3 analog input WB on PRA ECU
Noted.
LK7R
Post by LK7R »
Thank you.
LK7R
Post by LK7R »
Any news/plans on this request please?
Dan
Still on the list of things to do.
LK7R
Post by LK7R »
Hondata wrote:Still on the list of things to do.
nice
thx
monchiy2k
Post by monchiy2k »
im looking for this too!
LK7R
Post by LK7R »
Any news Hondata?
We plan to do a KManager release next month.
LK7R
Post by LK7R »
Hondata wrote:We plan to do a KManager release next month.
Great news!
TODA cams are on it's way to my car, this would be great help in getting the tune done.
Thanks for letting us know.
cheers
Dan
Try this: <old update removed>
LK7R
Post by LK7R »
Hondata wrote:Try this: <old update removed>
Wow! I'm on it ;-).
