HELP!!
bxplatano3000
HELP!!
Post by bxplatano3000 »
Was up guys, I have in issue, I've been trying to figur out for about a month now. Everytime I pump gas into my car(93) when I go turn un the car it's start sound like its not getting enough gas, so what I have to do is keep pumping the gas peddle while I'm turning the ignition for it to turn on. Then I have to keep it around 2k rpm for a couple of min for it to stay on. It only happens after I pump gas. Help...
bxplatano3000
Re: HELP!!
By the way I have a k24a4 swap in it.
Re: HELP!!
Has this been properly tuned on the dyno?
bxplatano3000
Re: HELP!!
Negative, all I have is just the basic map that comes with the kpro. I'll ive done to the motor is v2 intake and itr flywheel. What's your suggestion?
Re: HELP!!
Get it properly tuned and the problem should go away.
