S300 Cranking Ignition Timing
Johnny_9
Post by Johnny_9 »
What is the cranking ignition timing for the S300? Mine reads -4 at 31 celsius. Is that normal
Pic below is for the Flash Pro for reference.
Uploaded with ImageShack.us
Johnny_9
Re: S300 Cranking Ignition Timing
Post by Johnny_9 »
Some info from Hondata (S300) on this would be appreciated. There seems to be more limited info on this in the S300 vs Flashpro.
I read some where else that from a blog on a hondata seminar that cranking igniton does NOT use the ignistion tables.
Interested and need to know more about this.
Are you having trouble starting the car?
Johnny_9
Post by Johnny_9 »
I was comparing the stock P72 map which has a timing of "negative 4" (i.e 4 ATDC) at 500 rpm/3kpa.
I used a another after market ECU before and the timing at 500rpm/3kpa is way different 8 degree BTDC.
I just want to understand or confirm that in S300, that on firing (500 rpm) does the S300 ECU use a hidden cranking timing table* or is it using the ignition map at 500rpm/3kpa. At what point does the ECU switch to the main ignition map (from the hidden cranking map)
* I changed timing at 500rpm/3kpa and the engine still cranked at -4.SO ia m wondering what are those cells for and what should be the range of acceptable values
From my S300 datalog I can see that immediately after firing at 500 rpm the ghost traces the 500 rpm.3kpa cell.
I also want to know - does the cranking timing vary with ECT and if so that is the hardcoded values is cranking retarded 4 degree across all ECT?
As I using race cams i cant get the distributor/timing using "set timing" at 16 degrees
i also read this - Some programmable engine management systems have a default cranking advance of 15 degrees, a value about midway through the range of appropriate cranking advances. Smaller engines with faster cranking speeds need a greater ignition advance (up to 20 degrees), while slower cranking speeds of a high compression engine will require less advance (down to 10 degrees). The compression ratio of the engine will also determine the likelihood of kickback on starting. Engines with a low static compression ratio of 8:1 will accept an ignition advance of anything from 0-20 degrees without kick-back. A 10:1 compression ratio will reduce this to 15 degrees, 11:1 to around 10-12 degrees, while race engines using very high compression ratios of 12-13:1 can sometimes tolerate no cranking ignition advance at all.
Can cranking ignition be changed by rotating the distributor?
The above is from Flash Pro...guess you would change it is you radically upped the compression.
Johnny_9
Post by Johnny_9 »
Is your distributor is incorrectly set. would that affact crank timing, or can the ECU/sensor adjust for that?
Johnny_9
S300 Cranking Timing
Post by Johnny_9 »
Posted earler, but i have clarified and simplied my question
1) The above is from Flashpro. What is the cranking timing for the S300 - hot and cold. I have data logged mine and would like to know what is the range
2) Does advancing/retarding the distributer have any affect on crank timing, or does the S300 compensate for that?
Johnny_9
Post by Johnny_9 »
For reference
http://www.pencomputing.com/rsx/HondataSeminar.html
Hondata K-Pro Seminar March 13, 2004, Torrance, CA
"Cranking ignition values are in the first two rows, columns 8-10 in the table. Note that ignition is actually retarded there"
Question - is this applicable to S300?
Johnny_9
Post by Johnny_9 »
Johnny_9 wrote:For reference
I just datalogged
Cranking timing is -4. at ECT 32 Celcius
Post cranking, just after the engine fires, at 500rpm load 103Kpa the ecu traces the ignition map.
Engines seems to like -4 timing there also
Next the engine goes to about 700 rpm and load 6-7, whatever the timing is there
Johnny_9
Post by Johnny_9 »
Spunkster wrote:Are you having trouble starting the car?
Got a new ported head. Engine fires, gets up to 1,000 rpm then stalls.
Do i need to tune the
-Fuel Comp. ECT Open loop low load?
-Fuel Comp. ECT CLOSED loop low load?
or post start fuel trim for the first 20 sec after engine fires?
Johnny_9
Post by Johnny_9 »
Is the answer Open Loop ECT Fuel trims, as the HO2 has not warmed up?
