need help..
laeeqbest
need help..
Post by laeeqbest »
guys i have a jdm h22A type s with original specs ..everything is stock and i want to tune it with hondata s300.But i can't figure out how to do it so plz help me with this.
Luke
Re: need help..
Post by Luke »
have you any idea about tuning?
do you have a wideband-lambda?
do you have any further tools?
if not - get a tuner.
it's the cheapest way to do.
best regards Lukas
laeeqbest
base map of stock h22a type?
Post by laeeqbest »
well really thanks for replying sir..
now I have the s300 installed but the problem is i dont have the base map of my engine...plz if u could help i need base map of stock h22a jdm type s on s300 with p28 ecu....!
Luke
Re: need help..
Post by Luke »
there is no JDM H22 map available. from the 3 H22 I had (hondata map, crome conversion (fuel/ign tables), etc.) everyone differes from the other.
you'll need to get the car tuned, that it gets the power it has.
best regards Lukas
laeeqbest
Re: need help..
Post by laeeqbest »
thanks sir and another thing ....
when ever the i go above 7000 rpm a little puff of white smoke appears from the exhaust...?
is it a problem? if yes what can i do about it?
Luke
Re: need help..
Post by Luke »
white smoke can be burnt water.
that could be a sign for a broke head gasket. but here i'm not sure.
it's really better, that you get your car to someone, who knows, what he is doing.
it wouldn't be nice, if you damage your engine (if not happend yet) but fault.
be careful
