hi,
I find myself with a problem and I would like to help me to solve it, I have a k20a2 motor interface wiring Committee (PRA and PRB) and a control module PRC K-PRO, I would like to figure out what to modify to make it all work, then the material , motor and control unit camblaggio were provided to me without his original lambda sensor probe in the house but I PLX wideband, can I still make the engine work with this probe, or do I buy his original? Where do I connect the probe since they are devoid of plug?
thanks
Simone
swap in lotus elise
Re: swap in lotus elise
You should use the oxygen sensor from a PRB/PRC for this ECU. See http://www.hondata.com/techk20wiring.html for the o2 sensor wiring.
Where can I find a probe? you shall have some for sale? what is the exact code to search for the probe? thanks
can not really use the PLX wideband controller on the prc? I am obligated to buy this 36,531-PRB-A01?
can I have the wiring diagram and the corresponding pin of the controller PRC?
thanks
SImone
thanks
SImone
ok thanksHondata wrote:http://www.hondata.com/techk20wiring.html
can not really use the PLX wideband controller on the prc? I am obligated to buy this 36531-PRB-A01?
