P72 ECU - OBD1 - O2 heater circuit inop - fix?
Cynical 1
Post by Cynical 1 »
so, had a mishap with some road debris, and it affected and shorted out the O2 heater circuit on my obd1 P72.
i have tested all wires, and it it pointing towards the heater circuit control in the ecu as being bad.
is this repairable, or is the ecu now junk?
also - if i were to want to chip this with a hondata s300 (which can disable o2 heater from what i have read) will it still be a useable ecu?
yes - i googled, and came up empty.
thanks.
Re: P72 ECU - OBD1 - O2 heater circuit inop - fix?
We don't repair ECUs, and we recommend that you use an undamaged ECU when using our products.
Cynical 1
Post by Cynical 1 »
Spunkster wrote:We don't repair ECUs, and we recommend that you use an undamaged ECU when using our products.
i am aware you don't repair ecu's...
however - what part/component is damaged when this happens?
the ecu still functions normally - only code is 41 for the heater... and 34mpg...
