What BASEMAP to use for frankenstien motors ?
x6h0ztx
Post by x6h0ztx »
When chosen a calibration... do you go by the Block of the motor "B17" or the head "b16" ?
hpmx18
Re: What BASEMAP to use for frankenstien motors ?
Post by hpmx18 »
depending on the block internals is it str8 b17 or is it ls crank there is a difference
LGMotoring
IG:Lgmotoring_official
Lgmotoring.com
x6h0ztx
Post by x6h0ztx »
its all stock internals on the block...
Progress
Post by Progress »
use p28 singlecam vtec
tuning upon request
347-989-5028
9.23@167 B18C street/track tuned
HP unknown
x6h0ztx
Post by x6h0ztx »
That dont make any sense...
Can you explain how you figured what basemap for a Frankenstein motor ?
For example: B18a1 Block and B16 head. How would you know what map to use ?
keto06
Post by keto06 »
In general, it follows the block. You want to make sure it has the right fuel for the extra cc's of the motor, however, timing is more based on the head. So the answer is, both. :P
For a b17/b16 frank, I would use the b16 map. Its most likely got enough fuel to compensate for the bigger displacement and the timing is more likely to work. Id add 5% fuel just in case, or if you have any issues with a rough idle. If it was a straight b17, id say use the GSR map as I believe the head design is closer.
Obviously bigger cams and higher comp pistons will change the fuel/timing characteristics of the motor, but its usually still fairly easy to create basemaps. Ultimately no map is going to be right, or prolly even close to right, for your setup. Best thing you can do is put it on a dyno....either that or get a wideband and get the AFRS straight at least. Try researching plug reading to help dial in timing on the street, though max power is MUCH harder to find without a dyno.
07 Civic Si Sedan (sold)
17 Civic Si Sedan (daily)
02 RSX Type S (project)
Hit me up for free Hondata Help!
x6h0ztx
Post by x6h0ztx »
thank you, I been street tuning for a year and 6 months b4 i got it dyno tuned, with no wideband ! lolz !
I always used the b17 base map as a outline. i have worked with the b16 as an outline, but it seems to want to run rough with out giving any extra power.
Heres my Before and after Dynos below.
