d16z6 12 psi
d16z6 12 psi
I need a calibration for my d16z6 the bottom end is built with fJ rods and vitara's pistons. Stock head with stock intake manifold 550 RC injectors.
burmese434
- Contact:
Re: d16z6 12 psi
Do you have a wide band? Try this map but just watch ur af and 11psi would be max on a stock map sensor? If you have a 2 bar or 3bar just change it on the parameters.
Re: d16z6 12 psi
Cool thanks ya was reading I could not boost 12 with the stock map so just going to stick with 10
