d16z6 12 psi
gizmo3495
d16z6 12 psi
Post by gizmo3495 »
I need a calibration for my d16z6 the bottom end is built with fJ rods and vitara's pistons. Stock head with stock intake manifold 550 RC injectors.
burmese434
Re: d16z6 12 psi
Post by burmese434 »
Do you have a wide band? Try this map but just watch ur af and 11psi would be max on a stock map sensor? If you have a 2 bar or 3bar just change it on the parameters.
gizmo3495
Re: d16z6 12 psi
Post by gizmo3495 »
Cool thanks ya was reading I could not boost 12 with the stock map so just going to stick with 10
