Another anti-lag question
surfingsk8r
Ok I searched this and didnt come up with a clear answer. Under the settings for launch control you have your ign retard taht takes timing out from the set point in the map but my question is the fuel parameter if you have 15 in that box for example does it mean that its adding 15% of fuel on top of the map at that point or does it mean its adding 15 units of fuel to the map at that point. Thanks a million for any and all responses.
Re: Another anti-lag question
The fuel units are not percentage, they are just numbers like the fuel tables. a value of 200 is double the amount of fuel at 100 and 400 is double the value of 200.
surfingsk8r
Ok I think im understanding you so its by units not percentage so i guess my next question is if you had your activation set at lets say 6500 rpm and for the purposes of understanding all of the columns in that row said 1500 in the fuel table and you have the value in the fuel enrichment box set at 200 would that 200 get added to the 1500 if it crossed that cell and make it 1700 theoretically. Thanks again for the responses.
that is correct
surfingsk8r
That is awesome of you for helping me out you have just saved me alot of time and effort thank you.
