Suggestions for Kmanager
krystar
Post by krystar »
Since I come from a software background, just wanted to add some things that might help make the software more user friendly.
1) Ability to cascade and tile the active windows.
2) Ability to change the font colors on the Display window. Right now it's a dark red and bright green. the red is sometimes hard to see.
and this is a harder one
3) an autosmooth feature. in the dvd, you mentioned that it's always better to be smooth in the cam changes. at least from what I understand, in the cam angles, it's pretty much 0-30 on low cam and follows somewhat of a parabolic. then on high cam at vtec, u want to take it all the way to 50 and then slowly back it down. can't these two curves be attempted to be mapped to an actual function curve and then follow the points? I know that isn't as easy I make it sound. I've done some data analysis back in college. No real world experience.
so far, loving the kpro when I actually load in the map correctly (had a bit of a mishap but my fault)
krystar
Post by krystar »
Just to add to the list.
In options, settings, Display tab. there's a box for the size. I'm guessing that's the font size. It's set at 40 and you can't change it.
Also would it be possible to have 6 buttons added to the menubar. One for each window?
Also in the Tables screen, can you make the software select entire row(s) or column(s) when you click on the header row/column. Like if I click on the "1000" it'll select the entire 1000 rpm row for all MAP values.
Thanks much for a great system so far!
ares650
Post by ares650 »
Is there a autosmooth feature?
ares650
Post by ares650 »
Disable P0420 67?
