obd1 H22a jdm base map
greencivic_0789
hello hondata fourm members! i have a 95 civic ex coupe with the h22a jdm motor. running p72 with s300. im using smanager 1.4.8 and i need a good base map for 16 degree set timing running 345cc injectors. i need a base map for that. i would like the stock p13 jdm ecu map if that is possible. i would really appreciate it. thanks members! my names nick by the way.
greencivic_0789
Re: obd1 H22a jdm base map
i would rather not use the calibration that smanager provides. thank you. if anyone has a good base map that matches my description.greencivic_0789 wrote:hello hondata fourm members! i have a 95 civic ex coupe with the h22a jdm motor. running p72 with s300. im using smanager 1.4.8 and i need a good base map for 16 degree set timing running 345cc injectors. i need a base map for that. i would like the stock p13 jdm ecu map if that is possible. i would really appreciate it. thanks members! my names nick by the way.
I have been using this one i found on here works good on my jdm h22a with IHE mods. Cant say how good it is exactly until i get my af gauge to work
greencivic_0789
thanks but how come your injector size is stock 270cc and current size is 240cc? my stock jdm has 345cc injectors? i have a 92-96 jdm h22a. im thinking your using a jdm 97-01 h22?bb4lude wrote:I have been using this one i found on here works good on my jdm h22a with IHE mods. Cant say how good it is exactly until i get my af gauge to work
I wondered the same thing, its not my map but it works and i have the 345cc injectors also, i have the Jdm H22 1994 model.greencivic_0789 wrote:thanks but how come your injector size is stock 270cc and current size is 240cc? my stock jdm has 345cc injectors? i have a 92-96 jdm h22a. im thinking your using a jdm 97-01 h22?bb4lude wrote:I have been using this one i found on here works good on my jdm h22a with IHE mods. Cant say how good it is exactly until i get my af gauge to work
greencivic_0789
Same year as mine lol. And i tried the map and its crazy how rich it is on low speed cam. i was around 10 afr. And there are alot of over crossing lines on the tables im gonna work on it and get it all straightend out and when i get done with the calibration ill send it back to you so you can try it.bb4lude wrote:I wondered the same thing, its not my map but it works and i have the 345cc injectors also, i have the Jdm H22 1994 model.greencivic_0789 wrote:thanks but how come your injector size is stock 270cc and current size is 240cc? my stock jdm has 345cc injectors? i have a 92-96 jdm h22a. im thinking your using a jdm 97-01 h22?bb4lude wrote:I have been using this one i found on here works good on my jdm h22a with IHE mods. Cant say how good it is exactly until i get my af gauge to work
That would be awesome thanks! just discovered my problem with af gauge so will have that up and running today too :)
greencivic_0789
bb4lude wrote:That would be awesome thanks! just discovered my problem with af gauge so will have that up and running today too :)
yeah no problem. i almost have all the bugs worked out on this tune. so far its way better. so much quicker.
Sounds good man please do share once finished :) Ive got my afr gauge running now. My car was the same as yours with that map around 10 afr at low rpm, hopefully i haven't damaged anything running that rich. I set injectors to 345 cc reduced all fuel trim settings to 0 and its a lot better now. Does need more fuel at higher rpm though . What octane fuel are you tuning on?
greencivic_0789
im running only shell 93 octane... how bout you?bb4lude wrote:Sounds good man please do share once finished :) Ive got my afr gauge running now. My car was the same as yours with that map around 10 afr at low rpm, hopefully i haven't damaged anything running that rich. I set injectors to 345 cc reduced all fuel trim settings to 0 and its a lot better now. Does need more fuel at higher rpm though . What octane fuel are you tuning on?
Im assuming you're from USA?
Im running on the UK 99 Ron octane fuel which i believe is equivalent to approx 94 AKI octane (the US measure)
Any progress on the map?greencivic_0789 wrote:im running only shell 93 octane... how bout you?bb4lude wrote:Sounds good man please do share once finished :) Ive got my afr gauge running now. My car was the same as yours with that map around 10 afr at low rpm, hopefully i haven't damaged anything running that rich. I set injectors to 345 cc reduced all fuel trim settings to 0 and its a lot better now. Does need more fuel at higher rpm though . What octane fuel are you tuning on?
