OBD and logs
FlashPro Manager software
bgh_187
Re: OBD and logs
Post by bgh_187 »
It should be a easy fix then... Hopefully.
I'll hold off getting my car tuned until this has been sorted.
Croc999
Re: OBD and logs
Post by Croc999 »
i think no reason to stop tunng.
you got the CEL anyway and won't be able to get rid of it (have you tried "return ECU to stock" option? bacuase i didn't).
air pump is important only at cold engine operation and it doesn't affect anything else.
Euro S2000 MY07 F20C2
bgh_187
Re: OBD and logs
Post by bgh_187 »
No, I've not tried to return to stock. I may try that just to make sure it does clear it.
I'm not to bothered by this cel to be honest, I just don't like to see the engine light on all the time.
I'll need to try letting the car warm up to the point where the pump would normally be off, then clear the code and see if it stays off.
Can you still hear your pump come on when you start your car?
I'll check today again, but I think my one didn't.
Croc999
Re: OBD and logs
Post by Croc999 »
pump doesn't work at all.
clearing CEL doesn't help - it comes back almost immidiately.
