Electrical issues????
gorillahumper
Post by gorillahumper »
I rebuilt my d16 and dropped it in and finally got it running. It runs like ass. It skips like it runs on 2 cylinders at low throttle. Open it up it fires smooth. It would idle on its own with factory injectors, Wideband reads LEAN. I have the 450 dsm's in calibrated with hondata and it runs stoich but the hondata doesnt pick up any sensors....tps, map, coolant, nothing. It pulls the fuel map from all over the place, full throttle, no throttle, and all the way up to 7k rpm. The tach doesnt move when running. I dont have voltage coming out of the ecu for the distributor sensors. I have all the wiring plugged up correctly, checked for continuity to proper place on ecu harness. What do i do?????
Please help
