Basic Hondata NOobie Fundamentals(How Things Work)
turbocivic4
First off ive been reading about hondata etc. for a long time and read lots of stuff on boards but im still confused on how exactly the system works. Im on a small island and there is no tuners but theres a shop that is willing to tune for me but ill provide everything.
From what I understand ill need the following:S200b, Emulator, Pocket Programmer, DataLogging, RomEditor, Chips, Laptop and of course the dyno and uego.
So can someone explain the procedure that its done. From my understanding you would use the rom editor and enter changes , then download it to the emulator. Make a pass, datalog it and repeat, then when its got a good map etc. you use the pocket programmer and the file to burn a chip, then you have to put the chip into the ecu. Correct me if im wrong.
You are 90% correct. The emulator can be used to make real time changes (you do not download anything to it).
First of all you tune the car with the emulator and UEGO on the street and you get a decent map since dyno time is expensive. THen you go to the dyno to fine tune your full throttle maps. When you finish, you disconnect the emulator and burn a chip.
turbocivic4
turbocivic4
turbocivic4
The P28 doesn't look for a knock sensor, so the knock sensor is unused and no MIL/CEL will be produced.
Datalogging the AFR's is a nice feature, and you should take advantage of it.
The real-time emulator allows you to type in the changes, so you should avoid typing numbers into the cells that you're currently operating in to keep from upsetting the car. I've done it before and it totally screwed up my tables and I had to reload the previously saved file.
You can run with the emulator w/o the laptop by uploading the file to the emulator but only temporarily b/c it only retains the image for so long.
turbocivic4
turbocivic4
turbocivic4
You say to not change the cell the car is operating in, do you mean when I want to enter changes I kill the engine enter the changes(does it automatically download to emulator, or is cntrl e for that?) then start the car back up again.
Also from what I understand with the new emulator, you dont need the pocket programmer hooked up to emulate. The laptop would be hooked up to the datalog cable and to the emulator, then the emulator to the ecu. After done tuning you save the rom, disconnect the emulator and plug the pocket programmer in and burn. Cause the diagram on the instructions show the old emulator.
Also does the aem uego GAuge work with hondata?
turbocivic4
turbocivic4
