Info on Accord 95-01
fjartjdm
Post by fjartjdm »
I need a base map for a jdm accord swap 95-01 f22 or f23. Im looking for a base map for a SOHC VTEC map or what base map could i use.
danyo655
Re: Info on Accord 95-01
Post by danyo655 »
fjartjdm wrote:I need a base map for a jdm accord swap 95-01 f22 or f23. Im looking for a base map for a SOHC VTEC map or what base map could i use.
understand that f22 and f23 are 98% similar, but different compression ratios. so an f22 base will be too lean, i know cause i ran a stock f23 with a stock f22 calib, and boom goes the eng and pistons are fried, didnt think they were different CR's. i have a decent calib for a completely stock f23 with minor stuff like catback, CAI. if you use this set the rev limiter back to 6500. for safety reasons. and the accord gens are not 95-01 for engines, its 94-97 for f22's and 98-01 for f23's. good luck, use at own risk, works well on my stock f23 beater engine, waitin on the f20b to be finished
