Cannot install usb drivers PERIOD
carfreakrsx
Ive tried everything its told me to but for some reason the laptop will not recognize the ecu. It tells me that its an unknown device and thats it. Ive tried everything. Is there some magical way to get it? Do you need to magic touch? Im completely lost.
carfreakrsx
When i go to device manager it shows as unknown device and when click on it it gives me info on them then i can go to drivers and click on update drivers it tells me i already have the best driver for the system installed. Ive uninstalled it and still tells me the same thing. also when i plug it in it automatically installs a driver for it. but still will not connect.
carfreakrsx
i had some problems installing the driver aswell. the drivers are located in the kmanager folder when you download kmanager and install it to your pc. go to the device manager right click on the ecu and install drivers. after that manual select the drivers folder in kmanager (after you install it) and hopefully it should work :)
