k20a2 aem cai and a 4-2-1 DC sports race headers
When i installed the headers i've lost the low end torque but i gained on high revving on a stock ecu, now i bought a k-pro, can anyone send me a proper cal to get the best hp and torque for such a tune.
it is a euro type r
Thank you
it is a euro type r
Thank you
have you purchased the wideband o2 sensor? if so, try this.
File-->New-->Civic Type R (Euro)
Try the top (Dyno tuned) kal and the one that says ITR cams/hdr.
Do a WOT 3rd gear pull FOR EACH from 2k-redline and datalog it, then post it up here.
Try and do them on a flat road, and preferably the SAME road.
Enable lean protection.
Euro type r
I installed the wideband and made the modification in wiring, but the euro type r maps didnt work and didnt read A/F sensor, so i installed k20a2 rsx maps, i tried the cai tuned on third gear and the k20a stock map, and dataloged on third gear( attached). please check them up and advice. But i have some knocks when launching from the ground or when putting load on the engine. like 3to 5 knocks when launching.
thank you in advance.
I could be wrong, but i think the last two are the same.
Keep using the k20a2 Cold air map.
Do a much longer datalog from idle. Closer to 8-10mb. If its too big to upload, try speedyshare.com.
Do another WOT pull (or two) just like these in the middle of the map. (dont worry about starting and stopping it, I can cut it up)
I should be able to help you more then.
WOT daatalog
HI Keto06,
i loaded the cai tuned map, and started dataloging, it seems so lean because its cutting off fuel(attached) maybe because we have 98 octane fuel, I couldn’t continue data logging. So I installed another map( k20z cai tuned) and tried, same problem + V tec sensor error and the vtec malfunctioned(attached). So I got through fuel tables added fuel on all angles and all went well and vtec worked again, WOT data logged but still have some knocks indicated.
Can I increase the vtec low boundary to 4800 for example? I use this car for daily use.
Thank you keto06 in advance.
http://www.speedyshare.com/files/257882 ... ration.kdl
had a little time and I wanted to post a new kal so you could get a nice long datalog for me. 20minutes or so. Lots of mixed highway/street driving. Post to speedyshare so i can help on PT. (part throttle)
Good job on the WOT 3rd gear pulls. 3 or 4 in the next one is all you need. I liked that one pull in 4th as well. Try and get one of those as well.
I made a few changes here and there. Try not to change anything so I can keep things straight. if you do, make sure and post that kal.
long datalog
HI again,
i did a long datalog but it stopped automatically on the 8mb, ill do another one if u wish and post it again. it went well some knocks but much better than before, i had 2 lean cuts on the 6th gear around 3000rpm,
thanks again keto06
http://www.speedyshare.com/files/258041 ... h_gear.kdl
thanks again keto06
