Map Sensor
John Helps
Map Sensor
Post by John Helps »
Can a Honda 3 bar Map sensor be used on an alternative car ie. Mazda Rotary rx-7 or is it model specific
Many Thanks
DaX
Post by DaX »
Honda does not make a 3 bar map sensor. When boosting above 11 psi you use a General Motors [GM] 3 bar map sensor.
John Helps
Ok my mistake
cheers
