92sihbk
Posts: 10 Joined: Wed Nov 24, 2010 6:41 pm
Post
by 92sihbk » Thu Nov 25, 2010 9:07 pm
After I am finished tuning, I go to re-enable closed loop and when I do my air fuel ratio jumps everywhere. I've got it tuned to a pretty consistent 14.7 up to column 5 but as soon as I turn the stock narrowband back on the air fuel ratio jumps anywhere from 13.7 to 16.0.
Is there something Im missing, maybe some tweaking/adjustments I can make that will resolve this issue?
It almost seems as though the stock O2 sensor is "over correcting" itself if that makes any sense!
Thanks!!
Ryan
Johnny_9
Posts: 312 Joined: Sun Apr 09, 2006 5:12 am
Post
by Johnny_9 » Fri Nov 26, 2010 12:24 am
Just guessing, dont know for sure...play around with the O2 volts close loop...try something higher say 0.6v and see what happens...
92sihbk
Post
by 92sihbk » Fri Nov 26, 2010 7:42 pm
tried your suggestion with no luck.
Anyone else ever run into this or does everyone just tune and never enable to stock narrowband sensor again?
Thanks!
Ryan :twisted:
Johnny_9
Post
by Johnny_9 » Sat Nov 27, 2010 7:08 pm
what cams/engine specs?
please post your calibration and log. what strim values are u using?
92sihbk
Post
by 92sihbk » Sun Nov 28, 2010 4:18 pm
after searching around this forum some more, I found my answer and am pleased to say no more problem!!
I had to play with the " Rate of Change " values under the closed loop tab.
This forum rocks!
Thanks for the help Johnny 9
Johnny_9
Post
by Johnny_9 » Wed Dec 01, 2010 1:07 am
92sihbk wrote: after searching around this forum some more, I found my answer and am pleased to say no more problem!!
This forum rocks!
Did u make it faster or slower...pls share...what cams are u using?
