Ls/vtec breaking up/hitting brickwall around 4k-6k datalog.
ldbriggins
Post by ldbriggins »
I need to find out why my car is breaking up around 4k to 6k i checked the 12v source at the vtec pressure switch and at the ecu and it shows no volts with the acc on..:(.. i dont see why my car only hits 5psi when on the spring, because the spring is rated 7psi
'Boom, Dunnit'
ldbriggins
2nd run closed loop
'Boom, Dunnit'
ldbriggins
ne input?
'Boom, Dunnit'
ldbriggins
'Boom, Dunnit'
ldbriggins
bump
'Boom, Dunnit'
ldbriggins
Datalog in open loop..
seems my vtp is not on?
'Boom, Dunnit'
ldbriggins
calibrations
these are the calibrations i used rpm was swanging back and forth befroe my mil came on....
'Boom, Dunnit'
ldbriggins
this is a p28 ecu...
'Boom, Dunnit'
ldbriggins
plugs are gapped to .24 with 6 heat range
'Boom, Dunnit'
ldbriggins
i meant a heat range of 8.
'Boom, Dunnit'
ldbriggins
Turned out to be my plugs went to a colder heat range and disabled boost cut now everythings is a go. just needs dyno tuning/fine tuning :)
'Boom, Dunnit'
