Smanager wish list
as on one of the pages before mentioned:
I'd like to see to change my target lambda closer (not only 3 steps)
maybe also to change the "regeneration" time for the limiters, so that for the launch control the regeneration will start x rpm below the limited rpm and the same for the over-all limiter.
adding and removing speedlimiters would be good, too
other program use that already, so there should be a possibility to add that, isn't there??
would be great
best regards
Luke
would be great
best regards
Luke
A Few of my favs
FreshDA9 wrote:Bumping this back up!
Hows about serial logging support for widebands. no more playing with voltage offsets just put your usb in and select your port and go.
Also would like to add this one to the list of importance again.when looking at recorded Lambda and going to make a change. after changing the cell can you make it so that 1 cell clears itself. i have started making changes in maps before then customers interrupt me and i forgot where i have already made changes. think this would help us ADD people. thank you.
Funnyboy wrote:
2. Custom target AFR for whole map, not just 3 columns.
FreshDA9 wrote:Another option for widband logging. Being able to log only a selected gear. this will clean up alot of Overrun when on dyno or street. Just be able to make a check box for N-5 gear also have a lean stop logger so if your wide open put 16 as lean over by the time you see 16 in wot you should have the foot off the gas pedal anyways, or you could set it up as dont log fuel cut.
not having a load bearing dyno i must street tune partial throttle and fill in cells these features will help alot of us that have inertia dyno's.Luke wrote:as on one of the pages before mentioned:
EFI-101 & Advanced Certified*
SDHonda153
Wondering if there was any thought in maybe adding in a little more adjustment for A/C control. Right now we just have compressor shut-off above a certain RPM and throttle position.
Because now when I kick the A/C on it kills my idle down real low and stalls the car sometimes when I press the clutch in while slowing down. When my A/C's off it idles and slows down fine. I was looking at the eCtune software and they have a secondary IACV duty adjustment for when the A/C compressor is engaged. Can also kill the compressor if the RPM drops below a certain RPM and then reengages when it gets back above a certain RPM to help from stalling.
This would be Awesome!! ;)
Igntion Comps
Yes, I want to see this as well.RedR wrote:i´d like an option to see the ignition timing and the real timing the engine is running (based on the various compensation maps)
In other words a table/sensor that will show both values.
jiggacivic
Another one from me,
As I run a Honda in a Kit car and it has rather small wheels, Hondata reads approx 15% higher on speed. A potential problem I see is the maximum wheelspeed value for example nitrous control. This apears to max out at 157mph. I could be getting close to this in a years time, currently hitting 140+ on datalogs and I have more plans afoot for more power over the next year.
West
West
Its Small, Its Red, Its Mid engined, It has a B18 fitted, 250hp+per tonne + nitrous
Idle
Yes - Secondary IACV duty adjustment for when the A/C compressor is engaged, like Apexi Power FC.SDHonda153 wrote:Wondering if there was any thought in maybe adding in a little more adjustment for A/C control. Right now we just have compressor shut-off above a certain RPM and throttle position.
But try adjusting the Parameter>Ilde>Ilde Speed vs ECT (moving) to say 1,200 rpm and see if that helps.
possibility, to change target lambda and target voltage (when using wideband in closed loop) for secondary tables.
thought: one map for high power output, one table for rising milage (driving a bit leaner) or other fuel (E85)
EDIT says: a great feature would be an external trigger for setting the launch control. with an potentiometer (as a voltage divider) or with 2 buttons (+12V = 50/100rpm more - or - GND = 50/100rpm less)
that would save a lot of time and add more control on the track when different conditions uccur.
best regards Luke
best regards Luke
Closed Loop Indicator
Please add an indicator when closed loop is running.
Tip-In Indicator
Pls add an indicator to show when tip-in fuel is triggered....(parameter tracing)
S300 - Display TPS Volts (besides angle)
Good for trouble-shooting...
