Download tune off of ecu to adjust 3bar to Hondata 4 bar ?
Tosca
Post by Tosca »
I recently got my eg hatch tuned in FL while on vacation but am now in NJ. It was tuned with a msd 3 bar sensor. I have had problems with the map causing the engine to idle rough/low or the car shutting off. All indications lead to a bad map sensor including a cel for the map sensor. I just bought a Hondata 4 bar map from a local speedshop. I kno i have to change it in the parameters but it is light grey and wont let me select anything ? I tried to download the current tune to adjust but when i did it looks like a stock tune, injector size is set at 240cc stock and current size ? I have 660 cc injectors ? So how could this be my tune ? I want to leave everything the same except changing it to a 4bar map. Car will not start at all ? Please is anyone could lend a hand or any advice it will be greatly appreciated thank you in advance.
Engine is a B18c 60-1 turbo @15psi, hondata s300 p28 ecu.
Contact whoever did the tuning and ask them to email you the calibration from their computer.
Tosca
Post by Tosca »
I did but his laptop that had all of the tunes is fried so i'm SOL for now with no car !
Tosca
Post by Tosca »
Is there anyway you can do me a favor and write me up a base map tune so at least the car is driveable and it can make it to a tuner ? lmk if u can and i'll send u engine details thanks...
You will have to create your own basemap by clicking on New Calibration or contact the tuner you plan to have tune the vehicle. We do not create base calibrations.
