Lambda PLX 250 capacitor / resistor install question
fox30
Post by fox30 »
I have read the PLX instructions on both Hondata and PLX Devices web sites and got confused. Hondata talks about adding a resistor into the harness for fooling the ecu. PLX Doesnt mention adding a resistor but talks about adding a noise filtering capacitor. Do I do both? or can I get away with not doing any of it. Anyone can explain it better?
Last, I know what resistor to use but dont know what capacitor I should get. A capacitor didn't come with my kit PLX M250 kit.
What capacitor to use?
should be a chart, on the instructions page for the wideband install for all hondata equipped ecu's showing you the pinouts of each ecu model. Or even just a download of a PDF for each ECU showing which pinout is which would be nice. Help most people out during installs. Just a suggestion
96 GSR / B18C1 Built / AEBS T-Sleeves /~~/
No stickers / no nice rims / 10.4 seconds
other hobbies: PC gaming, Half-Life, Linux Administration, MotocrossKX250, kissing big tities
fox30
Post by fox30 »
nevermind I got it:
capacitor 0.1uf - 0.3uf with a minimum of 25Volt rating.
Figured I add it case someone needs to know
itr206
Post by itr206 »
my PLX came with the caps. that is for noise filtering . The resistors are for not getting the heated O2 code. i still didnt install the resistor, i cant find the wire i need, lol.
DaX
Post by DaX »
Why would you get a heater code? Isn't the sensor heated? [appologies for my ignorance]
fox30
Post by fox30 »
No , using the wideband is not heated, so you would need to add one 20ohm 10watt resisor (or 2 '10 ohm' 10 watt resistors in series) to fool the computer to think the heating element is there. Otherwise the check eng light would come on. the wide band doesnt have/use a heating element.
DaX
Post by DaX »
Thanks for the explanation.
