K20A2 Calibration required
Hi, Im new to having a KPRO and would like to add a map to it.
I have a UK 2002 Honda Civic Type R K20A2
AEM CAI
Spoon N1
Spoon B Pipe
Spoon Flywheel
Stage 3 Clutch
Once I have a map I know you need to open the RSX map in notepad and change the ECU type to UK and then resave as a .cal file. Upload it.
Please can someone help? Many thanks
AEM CAI
Spoon N1
Spoon B Pipe
Spoon Flywheel
Stage 3 Clutch
Thankyou for replying, Please can you advise why that is? From the CTROC ive been advised to load the "coid air map" and change to UK ECU, Please can you advise? Sorry for the noobish questions, Many thanksSpunkster wrote:We do not recommend editing the calibration files manual or changing the ECU type.
Re: K20A2 Calibration required
open PRB kal and PRA kal with notepad... and copy ONLY fuel,vtc and ignition tables from PRB to PRA....a2k00 wrote: Once I have a map I know you need to open the RSX map in notepad and change the ECU type to UK and then resave as a .cal file. Upload it.
That sounds like your best option...rikitaun wrote:open PRB kal and PRA kal with notepad... and copy ONLY fuel,vtc and ignition tables from PRB to PRA....a2k00 wrote: Once I have a map I know you need to open the RSX map in notepad and change the ECU type to UK and then resave as a .cal file. Upload it.
Im really sorry im a compleate noob to this, where do i get the cals? Have you got a screenshot to explain what you mean? Many thanksrikitaun wrote:open PRB kal and PRA kal with notepad... and copy ONLY fuel,vtc and ignition tables from PRB to PRA....a2k00 wrote: Once I have a map I know you need to open the RSX map in notepad and change the ECU type to UK and then resave as a .cal file. Upload it.
jajajaja... ok men.. I try it...a2k00 wrote:Im really sorry im a compleate noob to this, where do i get the cals? Have you got a screenshot to explain what you mean? Many thanksrikitaun wrote:open PRB kal and PRA kal with notepad... and copy ONLY fuel,vtc and ignition tables from PRB to PRA....a2k00 wrote: Once I have a map I know you need to open the RSX map in notepad and change the ECU type to UK and then resave as a .cal file. Upload it.
