2003 k24a4 Accord Turbo I A Need base Calibration
snyder2k9
Post by snyder2k9 »
turbo spools to quick i hit 11 psi and the dump tube open
my setup:
k24a4 stock block
SI 5 speed
Hasport Intake Manifold Adapter
RSX intake manifold
8lb flywheel
act 4 puck clutch
Turbo 3" catback
Godspeed GT-SERIES 38MM Wastegate
T3T4 turbo kit from RSX-S
1000cc Injectors
Aeromotive fuel-pressure regulator
Walbro 255
Turbine Turbocharger
Oil cooled only
6 blade propeler
Compressor Specs :
3" Compressor Inlet
1.990" or 50.55mm Minor
3.000" or 76.2mm Major
Compressor .50 A.R.
Compressor 57 Trim
M12 / T4 Compressor Housing
Turbine Specs :
T3 Type Turbine
11 Blade Type
2.25" Outlet
Turbine .64 A.R.
Turbine 76 Trim
2.207 " or 56.06mm Minor
2.567 " or 65.2mm Major
Exhaust Outlet Flange with 5 bolt design
This is my maping for k24a4 turbo
cukali
Post by cukali »
Still needing a map?
chemik
Post by chemik »
im not really understanding what this thread is about. Are you needing a base cal? or posting one on here for others to use? :)
2003 Accord K24a4 - TSX 6 SPD - 4.7 FD - Greddy Turbo - 550cc - KPRO
chemik
Post by chemik »
well it looks like youre requesting a map because this one shows stock injectors and sensor. someone help the man out!! :P
JeremyK24a1eg
Re: 2003 k24a4 Accord Turbo I A Need base Calibration
Post by JeremyK24a1eg »
Hey Cukali, could you possibly send me a map for a k24a1 with 410cc injectors, golden eagle rail, fpr, 02' Type-S manifold, kpro, race header, resonated test pipe, full 3 in exhaust to a 4in muffler. It would be greatly appreciated, thanks!
K24bella
Post by K24bella »
i am looking for a k24a4 turbo kal too. 1000cc t3/60-1 turbo stock k24a4.
